주요 콘텐츠로 건너뛰기
Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement
필요한 것
  1. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Heat the edge: 1 단계, 이미지 1개 중 1개
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the right adhesive: 3 단계, 이미지 3개 중 3개
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the bottom adhesive: 4 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the bottom adhesive: 4 단계, 이미지 2개 중 2개
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the left adhesive: 5 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the left adhesive: 5 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the left adhesive: 5 단계, 이미지 3개 중 3개
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the top adhesive: 6 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the top adhesive: 6 단계, 이미지 2개 중 2개
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice around the camera bezel: 7 단계, 이미지 1개 중 1개
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the back cover: 8 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the back cover: 8 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the back cover: 8 단계, 이미지 3개 중 3개
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  9. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Heat the camera bezel: 9 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  10. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the adhesive: 10 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the adhesive: 10 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Slice the adhesive: 10 단계, 이미지 3개 중 3개
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  11. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the camera bezel: 11 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the camera bezel: 11 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the camera bezel: 11 단계, 이미지 3개 중 3개
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  12. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Unfasten the motherboard cover: 12 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  13. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Unclip the right edge: 13 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Unclip the right edge: 13 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Unclip the right edge: 13 단계, 이미지 3개 중 3개
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  14. Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the motherboard cover: 14 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Cover Replacement, Remove the motherboard cover: 14 단계, 이미지 2개 중 2개
    • Grip the right edge of the cover and pull it off the motherboard.
결론
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
1가이드 댓글
AHA, so that part is the one with the camera lens covers, not the blue back case itself! THANKS!
J D - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 35
전체 시간: 617
