주요 콘텐츠로 건너뛰기
Motorola Moto G Stylus 5G (2022) Motherboard Replacement
필요한 것
  1. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 2개
    • Grab and remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Heat the edge: 3 단계, 이미지 1개 중 1개
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  5. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the right adhesive: 5 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the right adhesive: 5 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the right adhesive: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  6. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the bottom adhesive: 6 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the bottom adhesive: 6 단계, 이미지 2개 중 2개
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  7. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the left adhesive: 7 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the left adhesive: 7 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the left adhesive: 7 단계, 이미지 3개 중 3개
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  8. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the top adhesive: 8 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the top adhesive: 8 단계, 이미지 2개 중 2개
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  9. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice around the camera bezel: 9 단계, 이미지 1개 중 1개
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  10. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the back cover: 10 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the back cover: 10 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the back cover: 10 단계, 이미지 3개 중 3개
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  11. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Heat the camera bezel: 11 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  12. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the adhesive: 12 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the adhesive: 12 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Slice the adhesive: 12 단계, 이미지 3개 중 3개
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  13. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the camera bezel: 13 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the camera bezel: 13 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the camera bezel: 13 단계, 이미지 3개 중 3개
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  14. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Unfasten the motherboard cover: 14 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  15. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Unclip the right edge: 15 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Unclip the right edge: 15 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Unclip the right edge: 15 단계, 이미지 3개 중 3개
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  16. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the motherboard cover: 16 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the motherboard cover: 16 단계, 이미지 2개 중 2개
    • Grip the right edge of the cover and pull it off the motherboard.
  17. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the battery: 17 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the battery: 17 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the display: 18 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the display: 18 단계, 이미지 2개 중 2개
    • Use the pointed end of your spudger to pry and disconnect the display's press connector.
  19. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the antenna cable: 19 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the antenna cable: 19 단계, 이미지 2개 중 2개
    • Use the pointed end of your spudger to pry and disconnect the white antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  20. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the board connector: 20 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the board connector: 20 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the board cable's press connector.
  21. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the upper 5G mmWave antenna: 21 단계, 이미지 2개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Disconnect the upper 5G mmWave antenna: 21 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  22. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Unfasten the motherboard: 22 단계, 이미지 1개 중 1개
    • Use your Phillips screwdriver to remove the 3 mm-long screw securing the motherboard.
  23. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Reposition the graphite film: 23 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Reposition the graphite film: 23 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Reposition the graphite film: 23 단계, 이미지 3개 중 3개
    • Lift and fold the graphite film off the battery and flip it onto the motherboard.
    • Use caution not to tear the film. It's adhered lightly to the battery.
  24. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the motherboard: 24 단계, 이미지 3개 중 3개
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as it's removed.
    • During reassembly, make sure no cables or connectors become trapped underneath the motherboard.
  25. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Main Camera: 25 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Main Camera: 25 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Main Camera: 25 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip the motherboard over so the rear cameras are faced down.
    • Use the point of a spudger to pry and disconnect the main camera's press connector.
    • The camera may eject from the motherboard. Work slowly to avoid losing it.
    • Use a pair of tweezers or your fingers to grab and remove the camera.
  26. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the macro camera: 26 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the macro camera: 26 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the macro camera: 26 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry and disconnect the macro camera's press connector.
    • Grab and remove the camera.
  27. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the depth camera: 27 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the depth camera: 27 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the depth camera: 27 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry and disconnect the depth camera's press connector.
  28. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the 5G mmWave Antenna: 28 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the 5G mmWave Antenna: 28 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the 5G mmWave Antenna: 28 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip the motherboard over again so that the graphite film is facing upwards.
    • Insert a spudger between the left side of the 5G mmWave antenna and the motherboard.
    • Pry up to disconnect the press connector.
    • Use a pair of tweezers or your fingers to grab and remove the 5G mmWave antenna.
    • There is light adhesive holding the antenna in place.
  29. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Heat the tape: 29 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the front-facing camera for two minutes.
  30. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the graphite film: 30 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the graphite film: 30 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the graphite film: 30 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the graphite film near the front-facing camera.
    • Peel the graphite film and fully expose the front-facing camera's copper tape.
  31. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the copper tape: 31 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the copper tape: 31 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Peel the copper tape: 31 단계, 이미지 3개 중 3개
    • Use the tips of your tweezers to lift a corner of the front-facing camera's copper tape.
    • Grab and peel the copper tape from the motherboard.
    • This tape tears very easily. Work slowly and apply more heat if the tape feels stuck.
  32. Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the front-facing camera: 32 단계, 이미지 3개 중 1개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the front-facing camera: 32 단계, 이미지 3개 중 2개 Motorola Moto G Stylus 5G (2022) Motherboard Replacement, Remove the front-facing camera: 32 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry and disconnect the front-facing camera's press connector.
    • Remove the camera with your fingers or a pair of tweezers.
  33. Motorola Moto G Stylus 5G (2022) Motherboard Replacement: 33 단계, 이미지 1개 중 1개
    • The motherboard is all that remains.
결론
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
2가이드 댓글
Will replacing the mother board get rid of the FRP lock
James Stelljes - 답글
Thank you for a very disruptive step by step information hey help me achieve the confidence I needed to complete the task effortlessly thank you again.A+ keep it up.
Matthew Morrison - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 59
전체 시간: 1,506
