이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Continue to gently lift the back cover until all plastic clips have been released.
Remove the back cover.
Use the point of a spudger to pry up the rubber cover over the camera flash connector.
Remove the rubber cover.
Use the point of a spudger to pry up and disconnect the camera flash connector.
Loosen the midframe along the edges and lift it away from the body.
Remove the midframe.
Peel up and remove the tape securing the battery wires.
Peel up and remove the black tape that bridges the battery and the phone.
Slip the point of a spudger underneath the red and black battery wires and gently pry straight up.
이 단계에 사용된 도구:Tweezers$4.99-
Use tweezers or your fingers to de-route the battery wires from the plastic brackets.
Peel the black pull tab from battery and pull slowly but firmly to separate the battery from the frame.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using a spudger, remove the two metal pieces connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the rear camera to the motherboard.
Remove two 4.0 mm T3 Torx screws connecting the motherboard to the front casing.
다른 33명이 해당 안내서를 완성하였습니다.
댓글 14개
sir, my motorola g4-plus suddenly it off . i am not analyzed that problem, please help me
Hi,
My Moto G4 Plus has suddenly Dead. neither it is getting charged nor showing any response.
Please Help me. Its just 13 Months have been passed buying me this.
Sir i have a moto g4 plus handset sir when i press power button the device gets locked and when i press power button to open the phone the phone does not open and i have to restart the phone to unlock it and when i unlock it the phones works properly what could be the problem help me
please help me with the motherboard i wana buy motherboard for moto g4plus . phn got dead no power nothing is cuming even not service centre is ready to repair
