소개
This guide will walk you through the process of replacing the rear camera in a Motorola Moto G4 Plus phone.
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the motherboard to the rear camera.
다른 2명이 해당 안내서를 완성하였습니다.
