소개
If your front facing camera is damaged and not letting you shoot selfies or video chat, this guide will show you how to remove and replace it so your Motorola Moto G5 Plus is working at peak condition.
필요한 것
Use a SIM eject bit, SIM eject tool, or paper clip to remove the SIM card from your phone.
Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
Apply a suction cup to the display, near the middle of the left edge.
Pull the suction cup with firm, constant pressure to create a slight gap between the display panel and the rear case.
If the display doesn't separate even with significant force, apply more heat to further soften the adhesive and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99
Once the battery is loose, remove it from the phone.
Remove any remaining adhesive from the phone, and clean the entire area under the battery with isopropyl alcohol.
Apply a few new strips of pre-cut adhesive or Tesa tape.
Press the new battery firmly into place for 5-10 seconds.
Flip the motherboard over.
Detach the flat-top connector for the front facing camera.
다른 한 분이 해당 안내서를 완성하였습니다.
