주요 콘텐츠로 건너뛰기
Motorola Moto G7 Play Charging Port Replacement
필요한 것
  1. Motorola Moto G7 Play Charging Port Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto G7 Play Charging Port Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Charging Port Replacement: 2 단계, 이미지 1/1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Charging Port Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Play Charging Port Replacement: 3 단계, 이미지 2/2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Charging Port Replacement, Charging Port: 4 단계, 이미지 1/1
    • Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Charging Port Replacement: 5 단계, 이미지 1/1
    • Using the iFixit opening tool, carefully pry up the charging port assembly cover.
  6. Motorola Moto G7 Play Charging Port Replacement: 6 단계, 이미지 1/2 Motorola Moto G7 Play Charging Port Replacement: 6 단계, 이미지 2/2
    • Using an iFixit opening tool, detach the cables from the charging port assembly.
  7. Motorola Moto G7 Play Charging Port Replacement: 7 단계, 이미지 1/1
    • Using the iFixit opening tool, carefully pry up the charging port assembly.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Monserath Casillas
회원 가입일: 02/10/20
1,146 평판
안내서 5개 작성하였습니다
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 회원
CPSU-REGAN-W20S7G4
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
Travis Brubaker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 57
전체 시간: 8,654
