소개
When the Motorola G7 Play, models XT1952-3 and XT1952-2, no longer charges, it could be due to a failing charging port. This replacement guide provides efficient steps to get the device working again. If replacing the charging port doesn’t fix the issue, attempt to replace the battery with this guide.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
How long do you have to use the heat gun before the glue loosens?
Pamela DeMars - 답글
It's worked for me with about maybe 15-20 seconds of heating per side.
Matthieu Bister - 답글
I could not get the pick started under the cover. Ruined several tips. I started with a hair dryer and switched to a heat gun. Be careful with a heat gun! 😬
K Goatee - 답글
