주요 콘텐츠로 건너뛰기
Motorola Moto G7 Play Screen Replacement
필요한 것
  1. Motorola Moto G7 Play Screen Replacement, Front Display Screen: 1 단계, 이미지 1/2 Motorola Moto G7 Play Screen Replacement, Front Display Screen: 1 단계, 이미지 2/2
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the front screen. If you're using the iOpener, please review the instructions for proper use.
    • Use the plastic opening tools or picks to create an gap between the screen and the rest of the device.
    • Do not use the Jimmy or metal spudger on fragile components, as these tools may end up causing more damage than good.
  2. Motorola Moto G7 Play Screen Replacement: 2 단계, 이미지 1/1
    • Use the suction cup tool to lift the screen without damaging or scratching screen.
  3. Motorola Moto G7 Play Screen Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Play Screen Replacement: 3 단계, 이미지 2/2
    • Disconnect the ribbon cable to fully detach the screen from the device.
    • Remove the display assembly from the device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
curt caudle
회원 가입일: 02/15/21
349 평판
안내서 3개 작성하였습니다
댓글 2개
This is not correct at all, all you did was rip the screen off.
To anyone else looking for help use the battery replacement guide for this model and you’ll have much better instructions
Ender - 답글
I agree with Ender, this is the farthest thing from instructions on how to replace the screen. It’s just photos of how someone pulled the display off the frame. I can’t think of a reason anyone would do this. What’s the point?
Can we take away 30 points?
Jeana Morales - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 83
전체 시간: 4,184
