주요 콘텐츠로 건너뛰기
Motorola Moto G7 Play Speaker Replacement
필요한 것
  1. Motorola Moto G7 Play Speaker Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto G7 Play Speaker Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Speaker Replacement: 2 단계, 이미지 1/1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Speaker Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Play Speaker Replacement: 3 단계, 이미지 2/2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Speaker Replacement, Motherboard: 4 단계, 이미지 1/1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Speaker Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Speaker Replacement: 6 단계, 이미지 1/2 Motorola Moto G7 Play Speaker Replacement: 6 단계, 이미지 2/2
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Speaker Replacement: 7 단계, 이미지 1/2 Motorola Moto G7 Play Speaker Replacement: 7 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
  8. Motorola Moto G7 Play Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Motorola Moto G7 Play Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    • Use the spudger to remove the speaker from the top of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
curt caudle
회원 가입일: 02/15/21
349 평판
안내서 3개 작성하였습니다
댓글 2개
Nice guide to repair any mobile phone
Fisseha Desta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 24
전체 시간: 1,186
