주요 콘텐츠로 건너뛰기
Motorola Moto G7 Plus Battery Removal
필요한 것
  1. Motorola Moto G7 Plus Battery Removal, Remove the Screen: 1 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal, Remove the Screen: 1 단계, 이미지 2/2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: 2 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal, Remove the Display Cable Cover: 2 단계, 이미지 2/2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Battery Removal: 3 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal: 3 단계, 이미지 2/2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: 4 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal, Separate the Display From the Phone: 4 단계, 이미지 2/2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: 5 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal, Cut the Black Tape and the Connector Before Removal: 5 단계, 이미지 2/2
    • Use the blade end of a Halberd Spudger to cut through the two strips of black tape attached to the battery.
    • Use the flat end of a spudger to disconnect the battery from the phone.
  6. Motorola Moto G7 Plus Battery Removal, Remove the Battery: 6 단계, 이미지 1/2 Motorola Moto G7 Plus Battery Removal, Remove the Battery: 6 단계, 이미지 2/2
    • Take the battery out with the flat end of the spudger.
    • Handling batteries can be dangerous. Be very careful not to puncture the battery, as there are dangerous chemicals inside. Physical damage to the battery can cause it to burst into flame and release toxic smoke.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Jack Browers
회원 가입일: 02/10/20
382 평판
안내서 1개 작성함
Cal Poly, Team S22-G5, Regan Winter 2020 Cal Poly, Team S22-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S22G5
5 회원들
안내서 17개 작성하였습니다
댓글 4개
bricked, the display is not recognized anymore after re-attaching
Mrs Glue - 답글
as an additional information: my phone is bricked, because i severed a connection of the display, which is located at the bottom of the phone - you should only enter the pick up to a depth of ~ 2-3mm at the bottom!
Mrs Glue - 답글
Went as smoothly as possible, thanks very much. Only the glue under the battery was a serious pain in the butt.
Kevin Silbstedt - 답글
Followed the steps, and now my phone is working again. Thanks for the guide.
Gary Campbell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 86
30일 전: 347
전체 시간: 20,921
