주요 콘텐츠로 건너뛰기
Motorola Moto G7 Power Motherboard Replacement
필요한 것
  1. Motorola Moto G7 Power Motherboard Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Eject the SIM card tray: 1 단계, 이미지 2개 중 2개
    • Insert a SIM card eject tool into the small hole on the left side of of the phone.
    • Press gently until you feel the SIM card tray pop out slowly.
  2. Motorola Moto G7 Power Motherboard Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the SIM card tray: 2 단계, 이미지 2개 중 2개
    • Remove the SIM card tray from the phone.
    • When reinserting the SIM card tray, ensure that the hole is on the bottom side.
  3. Motorola Moto G7 Power Motherboard Replacement, Weaken the adhesive: 3 단계, 이미지 1개 중 1개
    • Apply a heated iOpener or a heat gun to the bottom edge of the screen for approximately two minutes to help soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G7 Power Motherboard Replacement, Loosen the rear cover: 4 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Loosen the rear cover: 4 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement, Loosen the rear cover: 4 단계, 이미지 3개 중 3개
    • Apply a suction cup to the rear cover, as close to the heated edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert an opening pick into the gap you created under the rear cover.
  5. Motorola Moto G7 Power Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the pick along the bottom of the gap to slice through the adhesive securing the rear cover to the midframe.
    • After being cut, the adhesive will sometimes stick back together as it cools. To prevent this, you can leave the pick in this edge after cutting, and continue the next steps with a new pick. Repeat this with each edge, leaving a pick and continuing with a new one.
  6. Motorola Moto G7 Power Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the pick along the gap on the same side of the phone as the SIM card tray to slice through the adhesive securing the rear cover to the midframe.
  7. Motorola Moto G7 Power Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the pick along the gap at the top of the phone to slice through the adhesive securing the rear cover to the midframe.
  8. Motorola Moto G7 Power Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Slightly lift up the rear cover starting from the right side.
    • This will prevent damage to the fingerprint sensor connector under the left side of the rear cover.
    • If lifting the rear cover is difficult, slice through any remaining adhesive with an opening pick. Reapplying the iOpener can also help weaken the adhesive.
    • Use a finger to press down on the fingerprint sensor until it separates from the rear cover.
  9. Motorola Moto G7 Power Motherboard Replacement, Remove the rear cover: 9 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the rear cover: 9 단계, 이미지 2개 중 2개
    • Remove the rear cover, taking care not to damage the fingerprint sensor.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
  10. Motorola Moto G7 Power Motherboard Replacement, Remove the fingerprint sensor: 10 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the fingerprint sensor: 10 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger into the divot at the top of the fingerprint sensor connector cover.
    • Gently pry the cover open.
    • Remove the cover.
  11. Motorola Moto G7 Power Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
  12. Motorola Moto G7 Power Motherboard Replacement, Remove the motherboard cover: 12 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the ten screws securing the motherboard cover to the midframe:
    • Nine 3.5 mm screws
    • One 3.0 mm screw
  13. Motorola Moto G7 Power Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger under the motherboard cover.
    • Pry the motherboard cover upwards to lift it from the motherboard.
    • Remove the motherboard cover.
  14. Motorola Moto G7 Power Motherboard Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
  15. Motorola Moto G7 Power Motherboard Replacement, Remove the front-facing camera: 15 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the front-facing camera: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to gently peel back the bottom of the copper sheet covering the metal shield below the front-facing camera.
  16. Motorola Moto G7 Power Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up on the front-facing camera's connector to disconnect it.
    • Remove the front-facing camera.
  17. Motorola Moto G7 Power Motherboard Replacement, Remove the rear camera: 17 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the rear camera: 17 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement, Remove the rear camera: 17 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up on the rear camera connector to disconnect it.
    • Remove the rear camera.
  18. Motorola Moto G7 Power Motherboard Replacement, Disconnect the display cable: 18 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Disconnect the display cable: 18 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up on the display cable to disconnect it.
  19. Motorola Moto G7 Power Motherboard Replacement, Disconnect the side buttons: 19 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Disconnect the side buttons: 19 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up on the upper side button connector to disconnect it.
  20. Motorola Moto G7 Power Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up on the lower side button connector to disconnect it.
  21. Motorola Moto G7 Power Motherboard Replacement, Disconnect the interconnect cable: 21 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Disconnect the interconnect cable: 21 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up on the interconnect cable connector to disconnect it.
  22. Motorola Moto G7 Power Motherboard Replacement, Disconnect the antenna cables: 22 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Disconnect the antenna cables: 22 단계, 이미지 2개 중 2개
    • Follow this guide for in-depth instructions on how to disconnect a coaxial connector.
    • Slide one of the tweezer's tips under the white wire until it's snug against the connector, and pry straight up from the board.
    • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
  23. Motorola Moto G7 Power Motherboard Replacement: 23 단계, 이미지 2개 중 1개 Motorola Moto G7 Power Motherboard Replacement: 23 단계, 이미지 2개 중 2개
    • Slide one of the tweezer's tips under the black wire until it's snug against the connector, and pry straight up from the board.
  24. Motorola Moto G7 Power Motherboard Replacement, Loosen the motherboard: 24 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the 3 mm screw securing the motherboard to the midframe.
  25. Motorola Moto G7 Power Motherboard Replacement, Remove the motherboard: 25 단계, 이미지 3개 중 1개 Motorola Moto G7 Power Motherboard Replacement, Remove the motherboard: 25 단계, 이미지 3개 중 2개 Motorola Moto G7 Power Motherboard Replacement, Remove the motherboard: 25 단계, 이미지 3개 중 3개
    • The SIM card tray also secures the motherboard to the midframe, so ensure that it has been removed before this step.
    • Insert the pointed end of a spudger under the top right corner of the motherboard to lift it from the midframe.
    • Remove the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G7 Power Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Clay Kim
회원 가입일: 02/16/21
12,370 평판
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 46
전체 시간: 2,110
