주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola SURFboard SB5101 Outer Cover Replacement
필요한 것
  1. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 3개
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 2 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 2 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Outer Cover Replacement, Unlocking Router: 2 단계, 이미지 3개 중 3개
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 3 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 3 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Outer Cover Replacement, Removing the Cover: 3 단계, 이미지 3개 중 3개
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
결론
In order to learn how to re-assembly your device, visit the Reassembly Guide.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bhavik Patel
회원 가입일: 10/13/14
276 평판
안내서 2개를 작성함
Clemson, Team 1-2, Benson Fall 2014 Clemson, Team 1-2, Benson Fall 2014 회원
CLEM-BENSON-F14S1G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 32
전체 시간: 1,355
