주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola SURFboard SB5101 Standby Key Replacement
필요한 것
  1. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Screw on the Back of the Device: 1 단계, 이미지 3개 중 3개
    • Locate the single 1 cm screw on the back of the device (enclosed by a red circle in the image).
    • Using a screwdriver with a Torx 10 hex screw, begin removing the 1cm screw by turning the screwdriver counterclockwise.
    • Remove the screw and set aside.
  2. Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 2 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 2 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Standby Key Replacement, Unlocking Router: 2 단계, 이미지 3개 중 3개
    • Rotate your device 90 degrees to the right so that the bottom of the device is facing you.
    • Locate the two horizontal slots on the bottom of the device.
    • You may need to remove the sticker on the bottom of the device to access these slots.
    • Insert the back end of the forceps into one of these slots. You may also use any other flat, narrow tool that fits into the slots.
    • Gently push the forceps into device. You should feel movement or hear a click, signifying this side of the device is unlocked.
    • Repeat with the other slot to completely unlock the device.
  3. Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 3 단계, 이미지 3개 중 1개 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 3 단계, 이미지 3개 중 2개 Motorola SURFboard SB5101 Standby Key Replacement, Removing the Cover: 3 단계, 이미지 3개 중 3개
    • Grab the top and the bottom of the device and gently pull the device open.
    • Continue pulling until you have completely removed the top cover of the device.
    • When reassembling your device, make sure the standby key is properly in place. See the Standby Key Guide for more information.
    • Also ensure that when you close the two sides of the cover the LED indicator lights are inside the information panel.
  4. Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: 4 단계, 이미지 2개 중 1개 Motorola SURFboard SB5101 Standby Key Replacement, Positioning the Standby Key: 4 단계, 이미지 2개 중 2개
    • Position the small black standby in the opening at the top of the case such that the wider teeth of the key is facing up.
    • Gently lower the key so the narrow teeth of the key are resting on the notch (circled in red) just below the opening at the top of the case.
    • If you plan to continue working on the device, check that this key is in place before finally closing the device.
결론
Your standby key has been successfully realigned.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Bhavik Patel
회원 가입일: 10/13/14
276 평판
안내서 2개를 작성함
Clemson, Team 1-2, Benson Fall 2014 Clemson, Team 1-2, Benson Fall 2014 회원
CLEM-BENSON-F14S1G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 49
전체 시간: 1,313
