주요 콘텐츠로 건너뛰기
Motorola syn1654A Headphone Speaker Replacement
필요한 것
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: 1 단계, 이미지 1/1
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: 2 단계, 이미지 1/1
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: 3 단계, 이미지 1/1
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: 4 단계, 이미지 1/1
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
결론
John Ware
회원 가입일: 02/24/14
325 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 회원
MTU-LAUER-S14S5G1
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 414
