주요 콘텐츠로 건너뛰기
Motorola syn1654A Microphone Replacement
필요한 것
  1. Motorola syn1654A Microphone Replacement, Microphone: 1 단계, 이미지 1/2 Motorola syn1654A Microphone Replacement, Microphone: 1 단계, 이미지 2/2
    • Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
    • To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
  2. Motorola syn1654A Microphone Replacement: 2 단계, 이미지 1/1
    • To expose the next screw, peel foam cover from the base toward the end of microphone.
    • Remove screw with screwdriver and place in a safe location.
  3. Motorola syn1654A Microphone Replacement: 3 단계, 이미지 1/3 Motorola syn1654A Microphone Replacement: 3 단계, 이미지 2/3 Motorola syn1654A Microphone Replacement: 3 단계, 이미지 3/3
    • With Screws removed, remove the microphone from foam and plastic cover to be inspected.
    • If the microphone is corroded or wires are frayed, it must be replaced.
  4. Motorola syn1654A Microphone Replacement: 4 단계, 이미지 1/1
    • Clip both wires to remove defective microphone.
    • Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
    • Align wires with corresponding pads on new microphone and solder in place.
    • For soldering, see the Ifixit soldering guide: How To Solder and Desolder Connections
결론
다른 한 분이 해당 안내서를 완성하였습니다.
John Ware
회원 가입일: 02/24/14
325 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 회원
MTU-LAUER-S14S5G1
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 365
