주요 콘텐츠로 건너뛰기
Motorola syn1654A Speaker Module Replacement
필요한 것
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: 1 단계, 이미지 1/2 Motorola syn1654A Speaker Module Replacement, Speaker Module: 1 단계, 이미지 2/2
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: 2 단계, 이미지 1/1
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: 3 단계, 이미지 1/1
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: 4 단계, 이미지 1/1
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
결론
Ben
회원 가입일: 02/24/14
104 평판
안내서 1개 작성함
Michigan Tech, Team 5-1, Lauer Spring 2014 Michigan Tech, Team 5-1, Lauer Spring 2014 회원
MTU-LAUER-S14S5G1
2 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 234
