주요 콘텐츠로 건너뛰기
Mr. Coffee TF6 Power Cord Replacement
필요한 것
  1. Mr. Coffee TF6 Power Cord Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
  2. Mr. Coffee TF6 Power Cord Replacement: 2 단계, 이미지 1/2 Mr. Coffee TF6 Power Cord Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
  3. Mr. Coffee TF6 Power Cord Replacement: 3 단계, 이미지 1/1
    • Gently lift the bottom cover, detaching it from the main body of the TF6.
  4. Mr. Coffee TF6 Power Cord Replacement, Power Cord: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the two 13mm Phillips screws that are securing the wire harness.
  5. Mr. Coffee TF6 Power Cord Replacement: 5 단계, 이미지 1/1
    • Carefully lift the wire harness from the base of the TF6, detaching it completely.
    • The power cord wiring is now completely accessible.
  6. Mr. Coffee TF6 Power Cord Replacement: 6 단계, 이미지 1/2 Mr. Coffee TF6 Power Cord Replacement: 6 단계, 이미지 2/2
    • Using a set of wire cutters, cut both leads of the power cord at the heatshrinked area where the leads split.
  7. Mr. Coffee TF6 Power Cord Replacement: 7 단계, 이미지 1/2 Mr. Coffee TF6 Power Cord Replacement: 7 단계, 이미지 2/2
    • Using your fingers, pry the heatshrink off from the power cord leads.
  8. Mr. Coffee TF6 Power Cord Replacement: 8 단계, 이미지 1/1
    • Using a 14-16 AWG wire stripper, strip the leads on the replacement power cord.
  9. Mr. Coffee TF6 Power Cord Replacement: 9 단계, 이미지 1/1
    • Solder the power cord's positive lead to the white nylon wire.
    • Solder the power cord's ground lead to the bronze nylon wire.
    • Ensure the correct leads are being soldered together (power to power, ground to ground). Soldering the incorrect leads together will result in hazardous conditions for both the TF6 and the user when the unit is powered on.
    • Consult the replacement power cord's user manual, packaging, or manufacturer in order to verify the power and ground leads.
결론
Andrew
회원 가입일: 01/24/14
116 평판
안내서 1개 작성함
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 회원
CPSU-REGAN-W14S13G18
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Excellent! very helpful...
NP Designs 123 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 718
