주요 콘텐츠로 건너뛰기
Munchkin Mozart Magic Cube On-Off Switch Replacement
필요한 것
  1. Munchkin Mozart Magic Cube On-Off Switch Replacement, Face plate: 1 단계, 이미지 1/2 Munchkin Mozart Magic Cube On-Off Switch Replacement, Face plate: 1 단계, 이미지 2/2
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube On-Off Switch Replacement: 2 단계, 이미지 1/1
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube On-Off Switch Replacement: 3 단계, 이미지 1/1
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube On-Off Switch Replacement: 4 단계, 이미지 1/1
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube On-Off Switch Replacement: 5 단계, 이미지 1/1
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube On-Off Switch Replacement: 6 단계, 이미지 1/1
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube On-Off Switch Replacement: 7 단계, 이미지 1/1
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube On-Off Switch Replacement, Frame Removal: 8 단계, 이미지 1/1
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube On-Off Switch Replacement, On-Off Switch: 9 단계, 이미지 1/1
    • Locate frame piece with battery pack and on-off switch, then remove two 6 mm Phillips #2 screws, located on either side of the battery pack.
    • Once removed, the on-off switch will easily slide out of position
  10. Munchkin Mozart Magic Cube On-Off Switch Replacement: 10 단계, 이미지 1/1
    • To disconnect the on-off switch, carefully desolder the connecting points and remove the switch.
    • Place the new switch into position, and solder back into place.
    • For soldering instructions please see this additional guide How To Solder and Desolder Connections
  11. Munchkin Mozart Magic Cube On-Off Switch Replacement: 11 단계, 이미지 1/1
    • To reinstall the switch, first place it back into position.
    • Insert the battery pack back into facing the correct way back into int battery pack slot.
    • Lastly, using the Phillips head screw driver to screw the screws back into place.
결론
Panos Valavanis
회원 가입일: 08/27/15
275 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Sullivan Fall 2015 USF Tampa, Team 1-4, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S1G4
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 602
