주요 콘텐츠로 건너뛰기
NETGEAR WGT624 v3 Capacitor Replacement
필요한 것
  1. NETGEAR WGT624 v3 Capacitor Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Capacitor Replacement: 2 단계, 이미지 3개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 2 단계, 이미지 3개 중 2개 NETGEAR WGT624 v3 Capacitor Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Capacitor Replacement: 3 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Capacitor Replacement: 4 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Capacitor Replacement: 6 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Capacitor Replacement, Capacitor: 7 단계, 이미지 1개 중 1개
    • Turn the motherboard so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Capacitor Replacement: 8 단계, 이미지 1개 중 1개
    • Locate the four capacitors.
  9. NETGEAR WGT624 v3 Capacitor Replacement: 9 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 9 단계, 이미지 2개 중 2개
    • Turn the motherboard so that the bottom is facing upwards.
    • Locate the two soldered contacts for each capacitor.
  10. NETGEAR WGT624 v3 Capacitor Replacement: 10 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Capacitor Replacement: 10 단계, 이미지 2개 중 2개
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
    • For proper soldering and de-soldering techniques, refer here.
    • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jonathon Sather
회원 가입일: 01/23/13
45 평판
안내서 3개를 작성함
Cal Poly, Team 3-31, Amido Winter 2013 Cal Poly, Team 3-31, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G31
3 회원들
안내서 12개를 작성함
1가이드 댓글
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
Vinod Kumar Polakonda - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 1,641
