주요 콘텐츠로 건너뛰기
NETGEAR WGT624 v3 Power Supply Replacement
필요한 것
  1. NETGEAR WGT624 v3 Power Supply Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Power Supply Replacement: 2 단계, 이미지 3개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 2 단계, 이미지 3개 중 2개 NETGEAR WGT624 v3 Power Supply Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Power Supply Replacement: 3 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Power Supply Replacement: 4 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Power Supply Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Power Supply Replacement: 6 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Power Supply Replacement, Antenna: 7 단계, 이미지 1개 중 1개
    • Turn the motherboard, so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Power Supply Replacement: 8 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the yellow tape that holds the wire.
    • Make sure that you set the tape aside on a clean surface, so that it can be reused.
  9. NETGEAR WGT624 v3 Power Supply Replacement: 9 단계, 이미지 3개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 9 단계, 이미지 3개 중 2개 NETGEAR WGT624 v3 Power Supply Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
    • The wire should now be completely separate from the motherboard.
  10. NETGEAR WGT624 v3 Power Supply Replacement: 10 단계, 이미지 1개 중 1개
    • Extend the antenna away from the device, so that it becomes straight.
  11. NETGEAR WGT624 v3 Power Supply Replacement: 11 단계, 이미지 3개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 11 단계, 이미지 3개 중 2개 NETGEAR WGT624 v3 Power Supply Replacement: 11 단계, 이미지 3개 중 3개
    • Find the clips that hold the antenna onto the router.
    • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
    • The antenna may take considerable force to remove.
  12. NETGEAR WGT624 v3 Power Supply Replacement: 12 단계, 이미지 1개 중 1개
    • Completely separate the antenna and wire from the rest of the device.
  13. NETGEAR WGT624 v3 Power Supply Replacement, Power Supply: 13 단계, 이미지 1개 중 1개
    • Unscrew the two 5 mm Phillips Head screws located at the front corners of the motherboard.
  14. NETGEAR WGT624 v3 Power Supply Replacement: 14 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 14 단계, 이미지 2개 중 2개
    • Take off the metal frame.
  15. NETGEAR WGT624 v3 Power Supply Replacement: 15 단계, 이미지 1개 중 1개
    • Turn over the motherboard, so that the bottom is facing up.
  16. NETGEAR WGT624 v3 Power Supply Replacement: 16 단계, 이미지 2개 중 1개 NETGEAR WGT624 v3 Power Supply Replacement: 16 단계, 이미지 2개 중 2개
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the three connections between the reset button and the motherboard
    • For proper soldering and desoldering techniques, refer here.
    • Pull the power source from the other side of the mother board once the solder is liquid.
결론
작성자
6다른 기여자 명과 함께
Nicole Slagle
회원 가입일: 01/25/13
83 평판
안내서 2개를 작성함
Cal Poly, Team 3-31, Amido Winter 2013 Cal Poly, Team 3-31, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G31
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 9
전체 시간: 1,940
