주요 콘텐츠로 건너뛰기
Nabi Jr Motherboard Replacement
필요한 것
  1. Nabi Jr Motherboard Replacement, Rear Case: 1 단계, 이미지 1/1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Motherboard Replacement: 2 단계, 이미지 1/1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Motherboard Replacement: 4 단계, 이미지 1/1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
  6. Nabi Jr Motherboard Replacement: 6 단계, 이미지 1/1
    • De-solder the grey wire from motherboard
  7. Nabi Jr Motherboard Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to peel off all yellow tape from the motherboard
    • Yellow tape is used in all locations where there is ribbon cable present.
  8. Nabi Jr Motherboard Replacement: 8 단계, 이미지 1/2 Nabi Jr Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
    • Pull black locking tabs up in opposite direction of ribbon cable to remove.
    • Use tweezers to pull the ribbon cable out of the locking tab's slot
  9. Nabi Jr Motherboard Replacement: 9 단계, 이미지 1/2 Nabi Jr Motherboard Replacement: 9 단계, 이미지 2/2
    • Lift motherboard to separate it the from the case shell.
결론
Kaila Joy
회원 가입일: 03/24/15
86 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,180
