소개
Use this guide to detach the damaged left shell so you'll be able to replace it with an undamaged shell. This guide can also be used with the 5 other Nerf N-Strike Elite Hail-Fire guides to replace other parts.
도구
부품
지정된 부품이 없습니다.
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
