주요 콘텐츠로 건너뛰기
Nest Cam IQ Camera Replacement
필요한 것
  1. Nest Cam IQ Camera Replacement, Camera: 1 단계, 이미지 1/1
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Camera Replacement: 2 단계, 이미지 1/1
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Camera Replacement: 3 단계, 이미지 1/1
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Camera Replacement: 4 단계, 이미지 1/2 Nest Cam IQ Camera Replacement: 4 단계, 이미지 2/2
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Camera Replacement: 5 단계, 이미지 1/2 Nest Cam IQ Camera Replacement: 5 단계, 이미지 2/2
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Camera Replacement: 6 단계, 이미지 1/3 Nest Cam IQ Camera Replacement: 6 단계, 이미지 2/3 Nest Cam IQ Camera Replacement: 6 단계, 이미지 3/3
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Camera Replacement: 7 단계, 이미지 1/1
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Camera Replacement: 8 단계, 이미지 1/2 Nest Cam IQ Camera Replacement: 8 단계, 이미지 2/2
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jas Ownby
회원 가입일: 09/08/23
800 평판
안내서 4개 작성하였습니다
University of New Orleans, Team 5-5, McDonald Fall 2023 University of New Orleans, Team 5-5, McDonald Fall 2023 회원
UNO-MCDONALD-F23S5G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 26
전체 시간: 161
