소개
If your Nest Cam IQ motherboard is overheating or shutting down, it requires replacement.
A functional motherboard connects all of your hardware. If you notice a burning smell coming from the motherboard or if the motherboard is off completely, consider changing out your motherboard.
필요한 것
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
