주요 콘텐츠로 건너뛰기
Nest Hello Battery Replacement
필요한 것
  1. Nest Hello Battery Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Battery Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Battery Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello Battery Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello Battery Replacement, Battery: 4 단계, 이미지 3개 중 1개 Nest Hello Battery Replacement, Battery: 4 단계, 이미지 3개 중 2개 Nest Hello Battery Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Once the back casing is removed, disconnect the battery cable and remove the battery from the device.
결론
다른 36명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Daniel Moore
회원 가입일: 01/14/20
902 평판
안내서 6개를 작성함
47가이드 댓글
Any recommendations as to where we can find a replacement battery? Model #, specs?
Patrick Ouellet - 답글
Flujoy 280mAh/3.7V Replacement Battery for Nest C1241290 Vido Doorbell Wired NC5100US Hello 1ICP7/17/26
About $16 from Amazon
Joel Lundi -
Battery and o-ring part source?
Ryan - 답글
What is the replacement battery?
Leon Sparrow - 답글
Search Amazon for the following and you should find several choices:
Nest Hello NC5100US C1241290 Video Doorbell Wired
JOHN ZUCKERMAN -
댓글 쓰기
조회 통계:
지난 24시간: 70
지난 7일: 460
지난 30일: 2,007
전체 시간: 80,505
