주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nest Hello O-Ring Replacement
필요한 것
    1. Nest Hello O-Ring Replacement, Casing and Faceplate: 1 단계, 이미지 1개 중 1개
      • Insert the pick between the black faceplate and white casing of the Nest Hello.
      • Pry the faceplate away from the device with the opening pick.
      • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
      • Completely remove the faceplate from the device, do not be afraid to pull hard.
      댓글 쓰기
    2. Nest Hello O-Ring Replacement: 2 단계, 이미지 2개 중 1개 Nest Hello O-Ring Replacement: 2 단계, 이미지 2개 중 2개
      • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
      댓글 쓰기
    3. Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 1개 Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 2개 Nest Hello O-Ring Replacement: 3 단계, 이미지 3개 중 3개
      • Insert opening pick between the white casing and the black internal circuitry and pry it out.
      • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
      댓글 쓰기
    1. Nest Hello O-Ring Replacement, O-Ring: 4 단계, 이미지 1개 중 1개
      • Remove the O-Ring (colored blue) from the device. It is placed around the edge of the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
2가이드 댓글
Is there a link available for spare replacement parts? I can’t seem to find anything other than replacement internal batteries . Thanks!
Andres Chavez - 답글 공유
Also looking for this replacement part. Googling did not produce results.
KB_KB - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 46
전체 시간: 5,280
