주요 콘텐츠로 건너뛰기
Nest x Yale Lock Keypad Replacement
필요한 것
  1. Nest x Yale Lock Keypad Replacement, Keypad: 1 단계, 이미지 1개 중 1개
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
  2. Nest x Yale Lock Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
  3. Nest x Yale Lock Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
  4. Nest x Yale Lock Keypad Replacement: 4 단계, 이미지 2개 중 1개 Nest x Yale Lock Keypad Replacement: 4 단계, 이미지 2개 중 2개
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
결론
작성자
3다른 기여자 명과 함께
Christopher Gonzalez
회원 가입일: 09/26/22
313 평판
안내서 3개를 작성함
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G3
5 회원들
안내서 5개를 작성함
1가이드 댓글
Where do you order the touchscreen from?
Mike Turrell - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 460
