주요 콘텐츠로 건너뛰기
Netgear WGR614v9 Capacitor Replacement
필요한 것
  1. Netgear WGR614v9 Capacitor Replacement, Lower Case: 1 단계, 이미지 1/1
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Capacitor Replacement: 2 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement: 2 단계, 이미지 2/2
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Capacitor Replacement: 3 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement: 3 단계, 이미지 2/2
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Capacitor Replacement: 4 단계, 이미지 1/1
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Capacitor Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Capacitor Replacement: 6 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement: 6 단계, 이미지 2/2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. Netgear WGR614v9 Capacitor Replacement, Capacitor: 7 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement, Capacitor: 7 단계, 이미지 2/2
    • Rotate the motherboard so that the top is facing up.
    • Set the motherboard on a flat clean surface.
  8. Netgear WGR614v9 Capacitor Replacement: 8 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement: 8 단계, 이미지 2/2
    • The capacitor can be found at the location shown.
  9. Netgear WGR614v9 Capacitor Replacement: 9 단계, 이미지 1/2 Netgear WGR614v9 Capacitor Replacement: 9 단계, 이미지 2/2
    • Rotate the motherboard so that the bottom is facing up.
    • Locate the two soldered contacts of the capacitor.
  10. Netgear WGR614v9 Capacitor Replacement: 10 단계, 이미지 1/3 Netgear WGR614v9 Capacitor Replacement: 10 단계, 이미지 2/3 Netgear WGR614v9 Capacitor Replacement: 10 단계, 이미지 3/3
    • Rotate the motherboard 180 degrees.
    • Do not refer to the pictures in this step for proper de-soldering and soldering techniques. They are for illustration purposes only.
    • Refer to this link for proper de-soldering and soldering techniques.
    • Pull the capacitor from the other side of the circuit board once the solder is liquified.
    • To replace the capacitor, orient the negative side of the capacitor (indicated by a white stripe and a negative sign) so that it aligns with the shaded white region of the circle indicating the capacitor's position on the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Moore
회원 가입일: 10/03/11
95 평판
안내서 1개 작성함
Cal Poly, Team 21-24, Maness Fall 2011 Cal Poly, Team 21-24, Maness Fall 2011 회원
CPSU-MANESS-F11S21G24
4 회원들
안내서 11개 작성하였습니다
댓글 한 개
looks like that's a 220microF at 25V right ?
probably better to replace it with a similar 220microF, but with higher voltage rating.
email_etran - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,230
