주요 콘텐츠로 건너뛰기
NeuTab N7 Pro Battery Replacement
필요한 것
  1. NeuTab N7 Pro Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Battery Replacement: 2 단계, 이미지 1/1
    • Follow the red and black wires from the battery to where they are soldered to the motherboard.
    • Warning: Use caution when handling a soldering iron to avoid injury or damage.
    • Use a soldering iron to separate the positive and negative wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N7 Pro Battery Replacement: 3 단계, 이미지 1/2 NeuTab N7 Pro Battery Replacement: 3 단계, 이미지 2/2
    • Insert plastic spudger under the battery and slide back and forth, separating the battery from the case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eric Fiske
회원 가입일: 02/09/16
430 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-1, Cheng Spring 2016 USF Tampa, Team 7-1, Cheng Spring 2016 회원
USFT-CHENG-S16S7G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,019
