주요 콘텐츠로 건너뛰기
NeuTab N7 Pro Speaker Replacement
필요한 것
  1. NeuTab N7 Pro Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Speaker Replacement: 2 단계, 이미지 1/2 NeuTab N7 Pro Speaker Replacement: 2 단계, 이미지 2/2
    • The speaker is attached to the back cover of the device.
    • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
  3. NeuTab N7 Pro Speaker Replacement: 3 단계, 이미지 1/3 NeuTab N7 Pro Speaker Replacement: 3 단계, 이미지 2/3 NeuTab N7 Pro Speaker Replacement: 3 단계, 이미지 3/3
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    • Be sure not to touch both the positive and negative terminal at the same time.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Travis McLean
회원 가입일: 02/09/16
322 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-1, Cheng Spring 2016 USF Tampa, Team 7-1, Cheng Spring 2016 회원
USFT-CHENG-S16S7G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 263
