주요 콘텐츠로 건너뛰기
NeuTab N9 Motherboard Replacement
필요한 것
  1. NeuTab N9 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use the soldering gun to separate all soldered wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N9 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Carefully pull the ribbons out.
  4. NeuTab N9 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the three 1 mm screws from the motherboard.
결론
Allan Lieu
회원 가입일: 09/20/17
306 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 218
