주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
New Nintendo 2DS XL Battery Replacement
필요한 것
  1. New Nintendo 2DS XL Battery Replacement, Back Cover Removal Preparation: 1 단계, 이미지 1개 중 1개
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The microSD card
  2. New Nintendo 2DS XL Battery Replacement, Back Cover Removal: 2 단계, 이미지 1개 중 1개
    • Use a tri‑point Y00 screwdriver to unscrew the four 6 mm‑long screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Battery Replacement, Case Separation: 3 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Battery Replacement, Case Separation: 3 단계, 이미지 2개 중 2개
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Battery Replacement: 4 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Battery Replacement: 4 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Battery Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Battery Replacement, Battery Removal: 5 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Battery Replacement, Battery Removal: 5 단계, 이미지 2개 중 2개
    • The battery is lightly adhered to its enclosure.
    • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
결론
다른 49명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Tim Newman
회원 가입일: 09/25/17
2,012 평판
안내서 4개를 작성함
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 회원
CPSU-FORTE-F17S18G6
5 회원들
안내서 24개를 작성함
16가이드 댓글
Does the 2ds xl have the same as the new 3ds xl
Royce davenport - 답글 공유
no. the 2ds shares the same battery type as the Nintendo DS and the Nintendo switch pro controller.
Jason - 공유
@avegaming Nintendo 3DS*, not DS
Jpeg - 공유
CTR-003 Battery
stephen cheshire - 답글 공유
Do I need to put a sticky pad on the new battery?
bryan sepulveda - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 62
지난 7일: 470
지난 30일: 2,040
전체 시간: 116,024
