주요 콘텐츠로 건너뛰기
New Nintendo 2DS XL Circle Pad Replacement
필요한 것
  1. New Nintendo 2DS XL Circle Pad Replacement, Back Cover Removal Preparation: 1 단계, 이미지 1개 중 1개
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. New Nintendo 2DS XL Circle Pad Replacement, Back Cover Removal: 2 단계, 이미지 1개 중 1개
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Circle Pad Replacement, Case Separation: 3 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Circle Pad Replacement, Case Separation: 3 단계, 이미지 2개 중 2개
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Circle Pad Replacement: 4 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Circle Pad Replacement: 4 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Circle Pad Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: 5 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Circle Pad Replacement, Battery Removal: 5 단계, 이미지 2개 중 2개
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: 6 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: 6 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Circle Pad Replacement, Camera Modules: 6 단계, 이미지 3개 중 3개
    • To more easily access this ribbon cable, flip the device so the back casing faces upwards. Gently slide the back casing forward, revealing the ribbon cable connecting to the motherboard.
    • Using a spudger, pry up the ZIF connector holding the ribbon cable.
    • Pull the ribbon towards the bottom casing and out of the connector.
  7. New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: 7 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Circle Pad Replacement, Circle Pad: 7 단계, 이미지 2개 중 2개
    • Remove the two 7.5mm phillips screws using a PH000 screwdriver.
    • Gently flip over the circle pad. Be aware that the pad is pressed into the back of the circle pad on the front of the case. Gentle prying will be necessary to pry if from the back of the circle pad.
    • Be aware that there is a black plastic disc that sits between the circle pad module and the circle pad stick. During reassembly, stand the unit on end and hang the plastic disc on the circle pad module and hold the stick from the front to press them back together.
  8. New Nintendo 2DS XL Circle Pad Replacement: 8 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Circle Pad Replacement: 8 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Circle Pad Replacement: 8 단계, 이미지 3개 중 3개
    • Using a spudger, lift up the ZIF connector (the hinge is located on the side closest to where the cable connects).
    • Remove the circle pad by pulling it away from the connector.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tim Newman
회원 가입일: 09/25/17
1,814 평판
안내서 4개를 작성함
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 회원
CPSU-FORTE-F17S18G6
5 회원들
안내서 20개를 작성함
댓글 5개
I can’t seem to find a New 2ds XL circle pad replacement online, does anyone know if a regular 2ds circle pad works? (Or perhaps a 3ds one?)
Dvdcd - 답글
Future Myself, the 3ds circle pad kinda works. The major change here is the screw holes, they were moved in on the 2ds xl, so if you do some sanding and finagling it will work, but it’s not elegant at all.
Dvdcd -
Excellent guide, although I believe the 2ds XL requires a Y00 and not a Y0
Gabrielle Watson - 답글
Can confirm the other comment, the outside screws are Y00.
If you're not confident removing the top ribbon you can just flip over the back carefully and change the circle pad that way.
You also don't have to remove the battery if it's too hard to remove, my one was stuck down like crazy so I just left it and everything is fine.
I just used a generic 2DS/3DS XL replacement circle pad and it works fine.
Daan - 답글
Does anyone know why removing the battery is necessary? Seems unrelated to the circlepad replacement.
Blank - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 88
지난 30일: 390
전체 시간: 16,151
