주요 콘텐츠로 건너뛰기
New Nintendo 2DS XL Front Buttons Replacement
필요한 것
  1. New Nintendo 2DS XL Front Buttons Replacement, Back Cover Removal Preparation: 1 단계, 이미지 1개 중 1개
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. New Nintendo 2DS XL Front Buttons Replacement, Back Cover Removal: 2 단계, 이미지 1개 중 1개
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Front Buttons Replacement, Case Separation: 3 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Case Separation: 3 단계, 이미지 2개 중 2개
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Front Buttons Replacement: 4 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 4 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: 5 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: 5 단계, 이미지 2개 중 2개
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. New Nintendo 2DS XL Front Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
  7. New Nintendo 2DS XL Front Buttons Replacement: 7 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the following wires from the motherboard using a pair of tweezers.
  8. New Nintendo 2DS XL Front Buttons Replacement: 8 단계, 이미지 2개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
  9. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Lift off the rubber cover on the A, B, X, and Y buttons.
    • Using tweezers, lift out the buttons.
  10. New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 10 단계, 이미지 3개 중 3개
    • Lift off the grey rubber cover on the start and select buttons.
  11. New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 11 단계, 이미지 3개 중 3개
    • Lift off the grey rubber membrane on the D-pad.
    • Using tweezers, lift the D-pad out.
  12. New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 1개 New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 2개 New Nintendo 2DS XL Front Buttons Replacement: 12 단계, 이미지 3개 중 3개
    • Lift off the grey rubber membrane covering the home button.
    • Using tweezers, lift out the button.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Tim Newman
회원 가입일: 09/25/17
1,814 평판
안내서 4개를 작성함
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 회원
CPSU-FORTE-F17S18G6
5 회원들
안내서 20개를 작성함
댓글 4개
after assembly, pressing ZL causes some kind of an electric short, and the console turns off immediately, help !
mos_boum - 답글
This usually occurs when you break the lower screen's power ribbon cable connector. It is not a ZIF connector and "unlatching" it will break it causing a loose fit. The shoulder button presses against the ribbon cable causing it to shift in the connector resulting in the speakers popping and the device turning off.
Mike -
OK. Lets say I can now change the buttons for replacement purposes only. My question is :where on the earth i can find buttons to replace??????
Robert - 답글
Now there is a full set of keys for 2dsxl. If you can't find it, you can google kasynparts
kasynlife - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 93
지난 30일: 299
전체 시간: 14,928
