주요 콘텐츠로 건너뛰기
Newport HT70 Pump Assembly Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
필요한 것
  1. Newport HT70 Pump Assembly Replacement, Pump Assembly: 1 단계, 이미지 1/1
    • Position the base assembly so that you may access it.
    • Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
  2. Newport HT70 Pump Assembly Replacement: 2 단계, 이미지 1/1
    • The base plate will then come apart from the rest of the device with the pump assembly attached to it, as depicted in the following photo.
    • Inspect pump assembly for any damage or looseness.
  3. Newport HT70 Pump Assembly Replacement: 3 단계, 이미지 1/1
    • If damage is found, replace the pump assembly by removing each tube individually and replacing as needed.
    • You may not need to replace the entire assembly if parts of it are still intact.
결론
Merek McGill
회원 가입일: 04/07/20
520 평판
안내서 5개 작성하였습니다
Cal Poly, Team S7-G5, Paton Spring 2020 Cal Poly, Team S7-G5, Paton Spring 2020 회원
CPSU-PATON-S20S7G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 196
