주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nexus 5 Back Cover Replacement
필요한 것
  1. Nexus 5 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Nexus 5 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Nexus 5 Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
결론
다른 43명이 해당 안내서를 완성하였습니다.
Gaetan
회원 가입일: 12/26/12
9,574 평판
안내서 18개 작성하였습니다
댓글 5개
Where do you find backs for the Nexus 5? Thanks!
Mark Brown - 답글
You can find them on Ebay
christian colon - 답글
can you tell me if removing the cover of the nexus 5 GPS stops working well?
daniele neri - 답글
Back cover LG spare part numbers are:
Black: ACQ86691011
White: ACQ86691012
Red: ACQ86691013
Google them. Done.
nexus555 - 답글
Thank you very much.
Jesse Wind -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 37
전체 시간: 72,232
