주요 콘텐츠로 건너뛰기
Nexus 6 Display Assembly Replacement
필요한 것
  1. Nexus 6 Display Assembly Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Display Assembly Replacement, Rear Case: 2 단계, 이미지 2개 중 1개 Nexus 6 Display Assembly Replacement, Rear Case: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iOpener
    $14.99
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
  3. Nexus 6 Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Display Assembly Replacement: 4 단계, 이미지 3개 중 1개 Nexus 6 Display Assembly Replacement: 4 단계, 이미지 3개 중 2개 Nexus 6 Display Assembly Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Display Assembly Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Nexus 6 Display Assembly Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With a spudger, unlatch the ZIF connector for the smallest ribbon cable in the center. See instructions for detatching ZIF connectors here
    • Use tweezers to release the ribbon cable.
  6. Nexus 6 Display Assembly Replacement: 6 단계, 이미지 2개 중 1개 Nexus 6 Display Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • With a spudger, unlatch the ZIF connector of the big ribbon cable on the side of the phone. See instructions for detatching ZIF connectors here.
    • Use tweezers to release the ribbon cable completely.
    • This connector and the ribbon are attached with a piece of amber anti-static tape. Make sure to release the tape from the ribbon before to pull it out of the connector.
  7. Nexus 6 Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the 2.3 mm T3 Torx screw on the top of the phone.
  8. Nexus 6 Display Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Peel the motherboard off of the screen with your hands.
  9. Nexus 6 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 1개 Nexus 6 Display Assembly Replacement, Display Assembly: 9 단계, 이미지 2개 중 2개
    • Remove the screen from the motherboard.
결론
다른 80명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Marina Moore
회원 가입일: 01/13/15
4,293 평판
안내서 7개를 작성함
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015 회원
CPSU-FORTE-W15S70G3
4 회원들
안내서 30개를 작성함
8가이드 댓글
its not antistatic tape its actually just Kapton tape and its ment only to protect the ZIF housing and keep the tabs from accidentally opening while being assembled along the line
Brian Grothouse - 답글
Is there any way to buy just the digitizer if so where and how much
Jason Larot - 답글
The digitizer and screen are a single unit. You can usually find the screen/digitizer for around $135-$140.
Eric Metzger -
Si può sostituire solo il vetro esterno o tutto il display?
Alessandro Carbone - 답글
be careful transferring the ear piece and microphone piece inserts from the old assembly to the new one, **if your replacement assembly does not come with those inserts already in place. ive cracked a few glasses on new assemblies just during this often overlooked step.
Steve B - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 249
전체 시간: 82,735
