주요 콘텐츠로 건너뛰기
Nexus 6 Motherboard Replacement
필요한 것
  1. Nexus 6 Motherboard Replacement, SIM Card: 1 단계, 이미지 1개 중 1개
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
  2. Nexus 6 Motherboard Replacement, Rear Case: 2 단계, 이미지 2개 중 1개 Nexus 6 Motherboard Replacement, Rear Case: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iOpener
    $14.99
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the iOpener Instructions for info on how to use it.
  3. Nexus 6 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  4. Nexus 6 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Nexus 6 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Nexus 6 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
  5. Nexus 6 Motherboard Replacement, Front Facing Camera: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a spudger to gently detach the front facing camera connector.
    • Remove the front facing camera using the tweezers.
  6. Nexus 6 Motherboard Replacement, Rear Facing Camera: 6 단계, 이미지 2개 중 1개 Nexus 6 Motherboard Replacement, Rear Facing Camera: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the spudger to release the rear facing camera connector.
    • Use tweezers to gently remove the rear facing camera.
  7. Nexus 6 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Nexus 6 Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With a spudger, unlatch the ZIF connector for the smallest ribbon cable in the center. See instructions for detatching ZIF connectors here
    • Use tweezers to release the ribbon cable.
  8. Nexus 6 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Nexus 6 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • With a spudger, unlatch the ZIF connector of the big ribbon cable on the side of the phone. See instructions for detatching ZIF connectors here.
    • Use tweezers to release the ribbon cable completely.
    • This connector and the ribbon are attached with a piece of amber anti-static tape. Make sure to release the tape from the ribbon before to pull it out of the connector.
  9. Nexus 6 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the 2.3 mm T3 Torx screw on the top of the phone.
  10. Nexus 6 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Peel the motherboard off of the screen with your hands.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Marina Moore
회원 가입일: 01/13/15
4,293 평판
안내서 7개를 작성함
Cal Poly, Team 70-3, Forte Winter 2015 Cal Poly, Team 70-3, Forte Winter 2015 회원
CPSU-FORTE-W15S70G3
4 회원들
안내서 30개를 작성함
1가이드 댓글
It worked great. Thanks!!!
Dustin French - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 298
전체 시간: 10,070
