주요 콘텐츠로 건너뛰기
Nexus 7 Speaker Assembly Replacement
필요한 것
  1. Nexus 7 Speaker Assembly Replacement, Rear Panel: 1 단계, 이미지 1/1
    • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
    • Do not use excessive force while prying the clips. They can be easily broken.
    Mine doesn't look like this. There is no metal band around it. The only opening looks like its between the front glass and back which is on the front. I'm afraid to try it for fear of breaking it. Any suggestions?
    Kim McCauley - 답글
    There is no front or rear panel. There’s no sign of any seam whatsoever. The front and back are one solid piece of plastic.
    Proud Liberal - 답글
  2. Nexus 7 Speaker Assembly Replacement: 2 단계, 이미지 1/2 Nexus 7 Speaker Assembly Replacement: 2 단계, 이미지 2/2
    • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
    My Nexus 7 looks nothing like this. These instructions are horrible as they do not work.
    Andy Garcia - 답글
    someone help? my nexus looks completely different
    Music Raider - 답글
  3. Nexus 7 Speaker Assembly Replacement: 3 단계, 이미지 1/3 Nexus 7 Speaker Assembly Replacement: 3 단계, 이미지 2/3 Nexus 7 Speaker Assembly Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
  4. Nexus 7 Speaker Assembly Replacement: 4 단계, 이미지 1/3 Nexus 7 Speaker Assembly Replacement: 4 단계, 이미지 2/3 Nexus 7 Speaker Assembly Replacement: 4 단계, 이미지 3/3
    • Pry up the rear panel along the left edge using the method described in previous steps.
  5. Nexus 7 Speaker Assembly Replacement: 5 단계, 이미지 1/2 Nexus 7 Speaker Assembly Replacement: 5 단계, 이미지 2/2
    • Gently lift and remove the rear panel up off the front panel assembly.
  6. Nexus 7 Speaker Assembly Replacement, Battery Cable: 6 단계, 이미지 1/2 Nexus 7 Speaker Assembly Replacement, Battery Cable: 6 단계, 이미지 2/2
    • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
    I have the newer version of Nexus and the battery connection inside is different from pictured here. I can't seem to get any part of the connector backed out. Any further details about how to accomplish this step?
    indianowen31 - 답글
    After my post I tried it again, and realized the connector comes straight UP, not OUT. Once I went this direction, the process was simple.
    indianowen31 - 답글
    I followed this, everything worked fine. Even though the battery is now charging, the OS doesn't recognise when the USB cable is connected to a wall socket or a PC. The battery icon when the tablet is shut down shows charging so it works, but the OS in itself doesn't seem to know about it...any ideas?
    /D
    Daniel Zakrisson - 답글
    Thanks for your guide. It makes the process very straightforward. Easier than I was expecting.
    Les Gordon - 답글
    Superb easy to follow guide. Thanks greatly, the nexus 7 lives on ! Just need to patiently wait for it charging now !
    stuart - 답글
    Yes, this is a really helpful guide. I wouldn't have had a clue without it, but it all turned out to be very simple. Thanks a lot!
    Ian Gibson - 답글
    I managed to break one of the two small golden pins to the right of the battery cable (obscured by the tool in the picture above).
    Is this terminal (sorry for the pun)?
    I tried re-assembling (without screwing the assembly back to the bezel) and the display doesn't work.
    gravelld - 답글
    Step 6 could be much clearer. I thought it meant to pry the connector upward, away from the surface. When I did this, all the pins broke off. The correct procedure would appear to be to slide the connector along the surface toward the wire side and battery, leaving the pins at parallel to the surface.
    Unfortunately I don't think my Nexus 7 is salveagable now.
    Warren Harris - 답글
    Watching a YouTube video helped. Dislodge the battery first, then pull the battery away from the connector and the connector will become dislodged quite easily.
    d_ratner_1999 - 답글
  7. Nexus 7 Speaker Assembly Replacement, Speaker Cable: 7 단계, 이미지 1/1
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
    Peel back the copper heat spreader for the Nvidia Tegra 3 processor
    Jack J - 답글
  8. Nexus 7 Speaker Assembly Replacement: 8 단계, 이미지 1/1
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
  9. Nexus 7 Speaker Assembly Replacement, Speaker Assembly: 9 단계, 이미지 1/1
    • Remove the following screws securing the speaker assembly to the display assembly:
    • Two 4.25 mm black Phillips screws
    • One 3.2 mm silver Phillips screw
  10. Nexus 7 Speaker Assembly Replacement: 10 단계, 이미지 1/1
    • Lift and remove the speaker assembly out of the Nexus 7.
결론
다른 36명이 해당 안내서를 완성하였습니다.
Walter Galan
694,877 평판
안내서 1,203개 작성하였습니다
댓글 7개
Hello. My Nexus 7 had issue with the speaker but I can't return it because i don't live in the USA. Can you tell me where can I buy speaker for the Nexus 7. Thanks.
bobski - 답글
Bobski, if you're not covered under warranty then you'll have to buy the speaker assembly on your own, from eBay or a third party site. They're kind of rare.
EXCELLENT guide, had no issues replacing mine and works great! Thanks iFixit!
Justin Redd - 답글
Would anyone happen to know the type of connector that is used to connect the nexus 7's speaker to its logic board?
Gray - 답글
Guide was great! Worked perfectly. Thank you!
milleniumofthecomet88 - 답글
easy took like 5minutes
David - 답글
Thanks so much, my nexus speaker had blown and I had another dead nexus laying around in my basement so with the help of this guide replaced the blown device
Seal-Space - 답글
Brilliant guide. Followed it without any problems and my Nexus now has excellent new sound quality.
Jack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 26,570
