주요 콘텐츠로 건너뛰기
Nexus S Rear Camera Replacement
필요한 것
  1. Nexus S Rear Camera Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the rear panel from the Nexus S.
  3. Nexus S Rear Camera Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Rear Camera Replacement, SIM Card: 4 단계, 이미지 2개 중 1개 Nexus S Rear Camera Replacement, SIM Card: 4 단계, 이미지 2개 중 2개
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Rear Camera Replacement, Rear Inner Frame: 5 단계, 이미지 1개 중 1개
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Rear Camera Replacement: 7 단계, 이미지 2개 중 1개 Nexus S Rear Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Rear Camera Replacement: 8 단계, 이미지 2개 중 1개 Nexus S Rear Camera Replacement: 8 단계, 이미지 2개 중 2개
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Rear Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Rear Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Rear Camera Replacement, SIM Card Board: 11 단계, 이미지 1개 중 1개
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S Rear Camera Replacement: 12 단계, 이미지 3개 중 1개 Nexus S Rear Camera Replacement: 12 단계, 이미지 3개 중 2개 Nexus S Rear Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S Rear Camera Replacement: 13 단계, 이미지 1개 중 1개
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S Rear Camera Replacement, Motherboard: 14 단계, 이미지 1개 중 1개
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
  15. Nexus S Rear Camera Replacement: 15 단계, 이미지 1개 중 1개
    • Repeat the same procedure as the previous step to disconnect the digitizer connector.
  16. Nexus S Rear Camera Replacement: 16 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
    • Remove the three Phillips screws securing the motherboard to the inner assembly.
  17. Nexus S Rear Camera Replacement: 17 단계, 이미지 1개 중 1개
    • Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
  18. Nexus S Rear Camera Replacement, Rear Camera: 18 단계, 이미지 2개 중 1개 Nexus S Rear Camera Replacement, Rear Camera: 18 단계, 이미지 2개 중 2개
    • Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
  19. Nexus S Rear Camera Replacement: 19 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift and remove the rear camera from the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Walter Galan
706,097 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 16
전체 시간: 3,404
