주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus S Speaker Replacement
필요한 것
  1. Nexus S Speaker Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the rear panel from the Nexus S.
  3. Nexus S Speaker Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Speaker Replacement, SIM Card: 4 단계, 이미지 2개 중 1개 Nexus S Speaker Replacement, SIM Card: 4 단계, 이미지 2개 중 2개
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Speaker Replacement, Rear Inner Frame: 5 단계, 이미지 1개 중 1개
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Speaker Replacement: 7 단계, 이미지 2개 중 1개 Nexus S Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Speaker Replacement: 8 단계, 이미지 2개 중 1개 Nexus S Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Speaker Replacement: 10 단계, 이미지 1개 중 1개
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Speaker Replacement, SIM Card Board: 11 단계, 이미지 1개 중 1개
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S Speaker Replacement: 12 단계, 이미지 3개 중 1개 Nexus S Speaker Replacement: 12 단계, 이미지 3개 중 2개 Nexus S Speaker Replacement: 12 단계, 이미지 3개 중 3개
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S Speaker Replacement: 13 단계, 이미지 1개 중 1개
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S Speaker Replacement, Motherboard: 14 단계, 이미지 1개 중 1개
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  15. Nexus S Speaker Replacement: 15 단계, 이미지 3개 중 1개 Nexus S Speaker Replacement: 15 단계, 이미지 3개 중 2개 Nexus S Speaker Replacement: 15 단계, 이미지 3개 중 3개
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  16. Nexus S Speaker Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  17. Nexus S Speaker Replacement: 17 단계, 이미지 2개 중 1개 Nexus S Speaker Replacement: 17 단계, 이미지 2개 중 2개
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
  18. Nexus S Speaker Replacement, Speaker: 18 단계, 이미지 1개 중 1개
    • Speaker remains.
    • Be careful, the earpiece part is united with the speaker, you could cut the flex.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Walter Galan
707,178 평판
안내서 1,203개를 작성함
3가이드 댓글
Where can I buy the speaker?
Fergal Daly - 답글
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
makenova - 답글
hey makenova,
I have the same problem. Did the soldering worked for you ?
Geert Meeusen -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 45
전체 시간: 7,043
