이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
Remove the battery from the Nexus S.
Use your thumb to slide the SIM card downwards from the SIM card slot.
Remove the SIM card.
Remove the six Phillips screws securing the rear inner frame to the inner case.
Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
Insert the plastic opening tool to the right of the power button.
Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
Disconnect the following cables from their respective sockets on the motherboard:
Headphone jack cable
Digitizer cable connector
Camera/SIM board connector
Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
Repeat the procedure for the digitizer and rear camera/SIM board connectors.
Remove the three Phillips screws securing the motherboard to the front display assembly.
Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
Lift and remove the motherboard.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
Where can I buy the speaker?
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
hey makenova,
I have the same problem. Did the soldering worked for you ?
