주요 콘텐츠로 건너뛰기
Nikon COOLPIX P7700 LCD Screen Display Replacement
필요한 것
  1. Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: 1 단계, 이미지 1/2 Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: 1 단계, 이미지 2/2
    • Push down and slide the lock of the battery compartment to the unlock position.
    • The battery door should pop open.
    • Remove the battery.
  2. Nikon COOLPIX P7700 LCD Screen Display Replacement: 2 단계, 이미지 1/1
    • Open the camera LCD screen so it's away from the body of the camera.
  3. Nikon COOLPIX P7700 LCD Screen Display Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 4.3 screw on both the top and bottom of the screen's casing.
  4. Nikon COOLPIX P7700 LCD Screen Display Replacement: 4 단계, 이미지 1/2 Nikon COOLPIX P7700 LCD Screen Display Replacement: 4 단계, 이미지 2/2
    • Place the camera lens-side down and twist the screen so that it is perpendicular to the camera.
    • Remove the 4.3 mm screw on the side of the casing using the Phillips #00 screwdriver.
    • Twist the screen in the other direction and remove the other 4.3 mm screw.
    • These screws are very brittle! Be careful not to strip the screws. If you find that one has become stripped, follow this guide.
  5. Nikon COOLPIX P7700 LCD Screen Display Replacement: 5 단계, 이미지 1/1
    • Remove the case from the screen.
  6. Nikon COOLPIX P7700 LCD Screen Display Replacement: 6 단계, 이미지 1/1
    • Replace the LCD display.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Seidel
회원 가입일: 03/11/15
145 평판
안내서 1개 작성함
Colorado Springs, Team 2-7, Panko Spring 2015 Colorado Springs, Team 2-7, Panko Spring 2015 회원
UCCS-PANKO-S15S2G7
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Do NOT follow this guide. There are numerous details left out of step 6 and there’s no troubleshooting guide. Most importantly, there’s no warning that this kind of repair really isn’t meant to be done by laypeople and that it’s to be done at the user’s own risk. These instructions don’t equip someone for this delicate task that, if done wrongly, can waste a lot of time and damage the camera, as happened in my case.
Alan Green - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 1,509
