주요 콘텐츠로 건너뛰기
Nikon Coolpix S51c LCD Screen Replacement
필요한 것
  1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Nikon Coolpix S51c LCD Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1개 중 1개
    • On back of LCD screen, locate the three screws underneath the ribbon.
    • Remove each screw using your screwdriver.
  7. Nikon Coolpix S51c LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Nikon Coolpix S51c LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Take out the rectangular component on the side where the screws were.
    • Carefully, pry apart the screen from the back casing using the spudger.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Ryan
회원 가입일: 04/12/11
167 평판
안내서 6개를 작성함
Cal Poly, Team 18-24, Garner Spring 2011 Cal Poly, Team 18-24, Garner Spring 2011 회원
CPSU-GARNER-S11S18G24
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 2,701
