주요 콘텐츠로 건너뛰기
Nikon D3100 LCD Screen Replacement
필요한 것
  1. Nikon D3100 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver for all of the screws.
    • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
  2. Nikon D3100 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Nikon D3100 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
    • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
  3. Nikon D3100 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Peel back the rubber grip on the right side of the camera using a spudger.
    • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
    • Remove two of the 5mm screws under the rubber grip.
  4. Nikon D3100 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove two of the 4mm screws on the left side of the camera.
  5. Nikon D3100 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Nikon D3100 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
    • Be careful not to pull the panel out too fast or the ribbon may be damaged.
    • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
    • Separate the back panel from the main body of the camera.
  6. Nikon D3100 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
    • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
  7. Nikon D3100 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the tape covering the ribbons. Be careful not to break the tape.
  8. Nikon D3100 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
  9. Nikon D3100 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the old LCD screen from metal plate.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Jet Mejia
회원 가입일: 09/26/16
662 평판
안내서 3개를 작성함
USF Tampa, Team 14-1, Eyestone Fall 2016 USF Tampa, Team 14-1, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G1
3 회원들
안내서 4개를 작성함
5가이드 댓글
Very helpful guide, so happy to have a non-cracked screen again!
Rob Cuthbertson - 답글
now, where can i buy this replacement screen here in the Philippines?
leumas_erbutco - 답글
does anyone have the part number for the replacement screen?
Lee Caterson - 답글
Très bien ce document, seulement l'écran LCD pour Nikon D3100 semble introuvable, et épuisé !!! Avez-vous une adresse valable pour commander?
gtre - 답글
Hello, regarde ici ça devrait correspondre:
https://fra.grandado.com/products/origin...
Lou Lou - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 36
지난 30일: 161
전체 시간: 15,140
