주요 콘텐츠로 건너뛰기
Nikon D5000 Sensor Filter Replacement
필요한 것
  1. Nikon D5000 Sensor Filter Replacement, Back Panel: 1 단계, 이미지 1/3 Nikon D5000 Sensor Filter Replacement, Back Panel: 1 단계, 이미지 2/3 Nikon D5000 Sensor Filter Replacement, Back Panel: 1 단계, 이미지 3/3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Sensor Filter Replacement: 2 단계, 이미지 1/3 Nikon D5000 Sensor Filter Replacement: 2 단계, 이미지 2/3 Nikon D5000 Sensor Filter Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Sensor Filter Replacement, Sensor Filter: 3 단계, 이미지 1/3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: 3 단계, 이미지 2/3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
    • Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
    • Disconnect a seventh ribbon cable in the lower-right corner.
  4. Nikon D5000 Sensor Filter Replacement: 4 단계, 이미지 1/1
    • Desolder the five wires attached to the back of the board.
  5. Nikon D5000 Sensor Filter Replacement: 5 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 5 단계, 이미지 2/2
    • Remove the five silver Phillips #00 4x4mm screws.
    • One is hiding under the wide ribbon cable in the lower-right corner.
  6. Nikon D5000 Sensor Filter Replacement: 6 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 6 단계, 이미지 2/2
    • Flip up the motherboard.
    • Remove the white cable connector by pulling it out of its socket with a spudger or fingernails.
  7. Nikon D5000 Sensor Filter Replacement: 7 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 7 단계, 이미지 2/2
    • Remove the L-shaped ribbon cable from both of its connectors.
  8. Nikon D5000 Sensor Filter Replacement: 8 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 8 단계, 이미지 2/2
    • Remove the three silver 5x5mm screws.
    • Between the metal backing plate and the standoffs for each screw is a copper washer. Don't lose them!
    • Flip the sensor board out.
    • Be extremely careful from this point on. Dust or scratches on any part of the sensor or its filters can affect picture quality.
  9. Nikon D5000 Sensor Filter Replacement: 9 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 9 단계, 이미지 2/2
    • Remove the four silver 3.5x3.5mm screws securing the dust cover.
    • Pull the cover straight up to remove it.
  10. Nikon D5000 Sensor Filter Replacement: 10 단계, 이미지 1/2 Nikon D5000 Sensor Filter Replacement: 10 단계, 이미지 2/2
    • To remove the sensor filter, pull back the rubber gasket to expose the edge. Use a spudger or opening tool to carefully pry out the filter.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jacob Rardin
회원 가입일: 04/14/14
1,390 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-28, Maness Spring 2014 Cal Poly, Team 13-28, Maness Spring 2014 회원
CPSU-MANESS-S14S13G28
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Excelente guía, solo que debo cambiar las cortinillas y creo que es por el frente de la cámara
alcova35 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 5,307
