소개
Use this guide to replace the mirror box and viewfinder.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
필요한 것
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Pull out ribbon cable from circuit asembly near front left of device.
다른 5명이 해당 안내서를 완성하였습니다.
