주요 콘텐츠로 건너뛰기
Ninja Mega Kitchen System BL770 Button Replacement
필요한 것
  1. Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: 1 단계, 이미지 2개 중 1개 Ninja Mega Kitchen System BL770 Button Replacement, Circuit Base: 1 단계, 이미지 2개 중 2개
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Button Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Button Replacement: 3 단계, 이미지 3개 중 1개 Ninja Mega Kitchen System BL770 Button Replacement: 3 단계, 이미지 3개 중 2개 Ninja Mega Kitchen System BL770 Button Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Button Replacement: 4 단계, 이미지 1개 중 1개
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Button Replacement, Button: 5 단계, 이미지 2개 중 1개 Ninja Mega Kitchen System BL770 Button Replacement, Button: 5 단계, 이미지 2개 중 2개
    • Locate which button you wish to replace.
    • On the back of the circuit board from the button, there are four solder pads with the designation "SW" followed by a number.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tommee Walker
회원 가입일: 08/22/17
850 평판
안내서 6개를 작성함
4가이드 댓글
Hi! I changed the “power button” and when I plugged it back, it went on without the press of the button, and it didn’t work. Think I may have made a lousy soldering job… :/
Luis - 답글
Got a dead BL780. Pretty sure it’s the power switch as it’s been harder and harder to push to turn on. Going to attempt to replace on the board. I’m guessing that it’s a tactile momentary switch and that the board controls the power activation instead of the tactile switch being a push on/push off. Any insight would be appreciated.
Mark - 답글
Where can I purchase the power button?
Mark
Cenek Picka - 답글
Where can buy switch? What part number is the switch?
Mountain Buoy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 43
전체 시간: 2,648
