주요 콘텐츠로 건너뛰기
Ninja Mega Kitchen System BL770 Power Cord Replacement
필요한 것
  1. Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 1 단계, 이미지 1/2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: 1 단계, 이미지 2/2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Power Cord Replacement: 2 단계, 이미지 1/1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Power Cord Replacement: 3 단계, 이미지 1/3 Ninja Mega Kitchen System BL770 Power Cord Replacement: 3 단계, 이미지 2/3 Ninja Mega Kitchen System BL770 Power Cord Replacement: 3 단계, 이미지 3/3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Power Cord Replacement: 4 단계, 이미지 1/1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 5 단계, 이미지 1/2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: 5 단계, 이미지 2/2
    • Check that the two red wires shown in the photos are properly soldered to the circuit board.
    • If they seem damaged, resolder the wires to the board.
    • If this doesn't solve the issue, proceed to step 6.
  6. Ninja Mega Kitchen System BL770 Power Cord Replacement: 6 단계, 이미지 1/1
    • If the 2 wires in the previous step are connected, it's time to check the 2nd area.
    • Remove the plastic covers and check that the wires are soldered correctly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tommee Walker
회원 가입일: 08/22/17
823 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 969
