주요 콘텐츠로 건너뛰기
Ninja NJ600 Power Cord Replacement
필요한 것
  1. Ninja NJ600 Power Cord Replacement, Blender Base Cover: 1 단계, 이미지 1/2 Ninja NJ600 Power Cord Replacement, Blender Base Cover: 1 단계, 이미지 2/2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Power Cord Replacement: 2 단계, 이미지 1/2 Ninja NJ600 Power Cord Replacement: 2 단계, 이미지 2/2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Power Cord Replacement: 3 단계, 이미지 1/3 Ninja NJ600 Power Cord Replacement: 3 단계, 이미지 2/3 Ninja NJ600 Power Cord Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Power Cord Replacement, Power Cord: 4 단계, 이미지 1/1
    • Remove these two screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
  5. Ninja NJ600 Power Cord Replacement: 5 단계, 이미지 1/1
    • Your blender and power cord should look like this now that the two screws have been removed.
    • In the next steps we will highlight two issues that your power cord may have.
  6. Ninja NJ600 Power Cord Replacement: 6 단계, 이미지 1/1
    • Your power cord is soldered to the circuit board as shown.
    • A loose or damaged connection could explain why your blender is not turning on.
    • Desolder the connection using the iFixit guide that describes this process.
    • Solder the wires back on to the circuit board. Refer to the iFixit soldering guide for assistance.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Power Cord Replacement: 7 단계, 이미지 1/2 Ninja NJ600 Power Cord Replacement: 7 단계, 이미지 2/2
    • If there were no issues with the soldering connection in Step 6, check the wiring in the picture shown.
    • Remove the zip ties with a pair of scissors. Then remove the plastic that covers the wires.
    • If the wires underneath the plastic covers are loose or disconnected, try to desolder and solder the wires. Use the iFixit soldering guide to assist in this step.
결론
Trevor Waite
회원 가입일: 04/01/15
275 평판
안내서 1개 작성함
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 19
전체 시간: 2,957
